unconfigure isis vlan
unconfigure isis [vlan all | {vlan} vlan_name] {level [1|2]}
Description
This command resets all configurable interface parameters to the defaults on one or all VLANs.
Syntax Description
vlan all Unconfigures IS-IS for all VLANs.
vlan_name Specifies a single VLAN for which IS-IS is unconfigured.
level [1|2] Specifies either level 1 or level 2.
Default
N/A.
Usage Guidelines
None.
The following command resets IS-IS configuration parameters for SJvlan:
unconfigure isis SJvlan
Platform Availability
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
